Home » Audio » Thermionic Emissions » PS Transformers
Re: PS Transformers [message #9741 is a reply to message #9739] Sat, 29 July 2006 06:59 Go to previous messageGo to previous message
Sorry; I assumed you were using the rated spec of the transformer and wall voltage. To measure off-load voltage you connect the primaries to the AC line input then use a voltmeter on the two legs of the secondaries right? But if you measure the voltages then why do you need the turns ratio? Thats already given by the primary and secondary voltage measurements.
Previous Topic: Filament Ratings
Next Topic: Fiament choke and filter scheme???
Current Time: Fri Nov 27 10:40:15 CST 2026
