Home » Audio » Source » Longest you've used a cartridge
Re: Longest you've used a cartridge [message #97343 is a reply to message #97340] Mon, 15 January 2024 19:57 Go to previous messageGo to previous message
Hi, A good link. I have a 10-200X digital scope that feeds a PC monitor or HDMI TV. It has its own screen but it is only about 6 inches diagonal and not good enough to see what you need to see. As Wayne noted even knowing what to look for it is difficult to determine if a stylus is worn enough to replace. Micro ridge and similar ones are especially hard to tell. If I have any doubts it gets replaced. Styli are replaceable many LPs are not. If it is an expensive cartridge especially one that the stylus is not user replaceable I send it off to a pro to evaluate and if needed replace. This does cost $$ though. Often in the area of $75-100. Still cheap insurance on protecting the LPs. For folks that have modest budgets I would stick to cartridges that have easily replaceable stylus. The 55E should not be difficult to find a replacement for. Check over on the vinylengine web site for help in getting a good source. I would assist on that, but have no cartridges by that company.
Previous Topic: Digital looks so simple, sometimes I miss the vinyl ritual
Next Topic: The Differences Between Vinyl And CD
Current Time: Sat Nov 07 19:05:30 CST 2026
