Home » Sponsored » Pi Speakers » Help With 4Pi Build
Help With 4Pi Build [message #97133] Tue, 31 October 2023 12:31 Go to previous message
DSD is currently offline  DSD
I am finally building a pair of 4 Pi speakers that I have put off for a very long time. I have a couple of questions that I hope someone can answer.
First, one of the inductors has become detached from the PCB crossover board. I see that a silicon glue was used, and that this takes a very long time to cure. Does anyone have a suggestion as to how I can re-glue the inductor to the board so that it can be mounted in a speaker within a week or two?
Second, for internal wiring, it looks that I can use 16 gauge speaker wire if I want to solder directly to the crossover board, or I need to use crimp connectors if I want to use a thicker gauge wire. 16 gauge wire seems a little thin, but will it make a difference, is there a preference?
Finally, both R11 or R13 insulation are recommended, but I think I remember reading somewhere on this forum that one is preferred. Is one better than the other?
Thanks,
Daniel
Previous Topic: Interested in building either 2 PI or 2 PI towers
Next Topic: New to pi speakers - four π plans
Current Time: Sun Sep 27 10:09:46 CDT 2026
