Home » Audio » Room Acoustics » Concrete and Tin
Concrete and Tin [message #97096] Tue, 24 October 2023 19:02 Go to next message
I have access to a building with a rather large main area. It is 545 square feet (ca. 51 m²), 20 foot tin ceiling, with brick as two walls and sheet rock as the other two.
How acoustically sound is that area?
Re: Concrete and Tin [message #97098 is a reply to message #97096] Tue, 24 October 2023 21:42 Go to previous messageGo to next message
It's probably not the best. I would expect problems at low frequencies from room modes and also midrange and higher frequencies from lively reflections. Not sure about the roof either - hopefully it doesn't vibrate and buzz.
Re: Concrete and Tin [message #97116 is a reply to message #97098] Sat, 28 October 2023 17:38 Go to previous messageGo to next message
Wayne Parham wrote on Tue, 24 October 2023 21:42
Oh, it will. I speak from experience.
If you have floor speakers, try propping them up on cinder blocks. I think the air gap is what makes the difference, rather than leaving the speakers on the concrete floor. If that doesn't help, try throwing a rubber mat underneath the speakers, like what you'd use as a mouse pad.
Re: Concrete and Tin [message #99072 is a reply to message #97116] Mon, 03 November 2025 12:21 Go to previous message
Becky is currently offline  Becky
Nice space! It sounds awesome. I’m not an acoustic pro, but with all those hard surfaces and the high tin ceiling, it will probably be pretty echoey and bright. Adding some rugs, curtains or panels would really help absorb the sound. Brick walls especially reflect a lot, with a few soft materials around, it will sound more better and nice.
Previous Topic: How to keep the neighbors' noise out
Next Topic: Drapes or Curtains
Current Time: Wed Nov 18 00:33:24 CST 2026
