Home » Audio » Thermionic Emissions » Seeking info - Antique Sound Usa ASUSA K2003 amp
Re: Seeking info - Antique Sound Usa ASUSA K2003 amp [message #97033 is a reply to message #97032] Thu, 28 September 2023 20:36 Go to previous messageGo to previous message
Hi, I believe before I replaced the sockets I would attempt to clean the pins. One thing that has worked for me is using de-oxit and a pipe cleaner (toothpicks can sometimes be used). Another trick is to get something like a really fine tip screwdriver (1mm or 1.5m tip) and push it into the pin sockets between the metal pin and side wall. Be really gentile as you want to "pinch" the connector and not squash it. Sometimes a pointed object like a needle can work . It depends on the construction of the pins. An alternative that might also work is to get some "socket savers" These are similar to tube bases but go between the tube and the original socket. The ones I have seen have slightly larger diameter pins and will make better contact in the existing socket than a tube would. Also verify that the tube pins are clean and not covered with oxide. That can be cleaned with steel wool, sand paper and so on.
Previous Topic: EL34 tubes - RFT vs EI Yugoslavia
Next Topic: Optimal settings for 6P3S-E output tubes in Leben CS-600(X)s
Current Time: Sat Nov 07 13:24:30 CST 2026
