Home » Sponsored » Pi Speakers » 3Pi front soundstage build
Re: 3Pi front soundstage build [message #96357 is a reply to message #96349] Fri, 10 February 2023 15:27 Go to previous messageGo to previous message
JakeAlmighty
Hey Wayne, thanks for all the info.
I will reinforce the baffle cutout, I'll sleep better without the woofer hanging there off a 1/4" of mdf.
Online search seemed to indicate that the main difference rockwool vs fibreglass for speaker applications is that the rockwool is quite a bit denser - likely blocks air/soundwaves more than expected in the design. In your opinion would you expect that to be neutral or a negative overall? (I don't have a proper near-field mic to build it and test it properly unfortunately)
I don't mind going and buying fibreglass if you think using the rockwool is a bad idea. It would be R12 pink fibreglass at 3.5" thick.
cheers,
Jake
Previous Topic: JBL 2226 repair
Next Topic: long wall setup
Current Time: Thu Oct 22 23:22:41 CDT 2026
