Home » Audio » Thermionic Emissions » Class A, AB1, B, C Operation/Modes (How Class A, AB1, B, C Modes Work and Their Strengths and Weaknesses)
| Re: Class A, AB1, B, C Operation/Modes [message #96344 is a reply to message #96343] |
Tue, 07 February 2023 20:37   |
positron
Messages: 164 Registered: May 2020
Master |
gofar99 wrote on Tue, 07 February 2023 19:33Hi, All my amps are U/L. Nearly no global NFB (just 3 db for stability at way above band possible resonanaces). And yes indeed...everything matters. It took a long time to figure out how to best use my Martin Logan ESLs. They tend to be troublesome loads for some amps (none of mine though) and placement is critical.
Hi Bruce,
Yes, I have heard Martin Logan's are a difficult load. i take it the
impedance varies wildly?
I agree Bruce, everything matters.
I am not running any global negative feedback, just a very small amount
of cathode/current feedback for the output tubes.
To help match woofer to full range driver, I am currenty using a 15"
piece of 18 gauge wire. I have 6" available, or no extra wire, or
other custom lengths if necessary.
You are so right concerning speaker placement.
Nice post Bruce. Appreciate your knowledge and input.
I guess back to Class A, AB1, B, and C amps.
Cheers and all the best Gents.
pos
By: positron on Sun, 05 February 2023 20:40
By: gofar99 on Mon, 06 February 2023 20:38
By: positron on Tue, 07 February 2023 16:13
By: gofar99 on Tue, 07 February 2023 19:33
By: positron on Tue, 07 February 2023 20:37
By: gofar99 on Thu, 09 February 2023 21:01
By: positron on Thu, 09 February 2023 21:35
By: positron on Tue, 28 February 2023 19:04
By: gofar99 on Wed, 01 March 2023 19:45
By: positron on Sun, 05 March 2023 00:33
By: gofar99 on Sun, 05 March 2023 08:10
By: positron on Mon, 06 March 2023 19:01
By: gofar99 on Tue, 09 May 2023 21:30
By: positron on Tue, 05 September 2023 23:48
By: gofar99 on Fri, 08 September 2023 21:12
By: positron on Thu, 12 October 2023 11:21
By: positron on Fri, 03 November 2023 12:22
By: gofar99 on Fri, 03 November 2023 20:58
By: positron on Sun, 05 November 2023 01:38
By: positron on Thu, 07 December 2023 23:12
By: gofar99 on Mon, 18 December 2023 20:20
By: positron on Tue, 16 January 2024 21:32
By: gofar99 on Wed, 24 January 2024 20:31
Current Time: Wed Oct 28 10:57:13 CDT 2026
