Home » Audio » Craftsmen » Stripping dye off keyboard
Re: Stripping dye off keyboard [message #96316 is a reply to message #96314] Sun, 29 January 2023 19:48 Go to previous messageGo to previous message
Hi, I have to presume from the discussion that it is an attached keyboard and not a plug in for a PC. If it was that then the answer is replace it. They are not costly. Since it is hair dye I might consider something like hydrogen peroxide to bleach it out. Even bleach might work. As noted the possibility of damage is quite real. If it is a costly device then a repair shop might replace the keyboard for a reasonable fee. Plus you can go on U-tube to see if anyone has already done that procedure. I am not a great fan of U-tube, but once in a while there are good things like this.
Previous Topic: Your go-to "holder"
Next Topic: How Big Is Your Shop?
Current Time: Wed Nov 04 17:17:08 CST 2026
