Home » Audio » Craftsmen » Stripping dye off keyboard
Re: Stripping dye off keyboard [message #96314 is a reply to message #96313] Sun, 29 January 2023 12:37 Go to previous messageGo to previous message
The problem, of course, is to use a solvent that will dissolve the dye without attacking plastic parts or anything that might have been silkscreened or painted on your keyboard.
I generally like to use flux removers and/or alcohols for circuit boards. I use (automotive) brake cleaner on really tough stains, but it will destroy most plastics so that's not an option for you. And really, flux remover will damage some plastic and some silkscreens, as well as PCB markings done in ink, like an ECO level, serial-number or revision number hand-written on a board. Isopropyl alcohol is usually pretty safe, but even that can damage some materials. Still, I'd start there 'cause it's the most "friendly" of the three solvents mentioned in this paragraph.
Using 91% isopropyl alcohol, rub a little on a part of the keyboard that's safe, like behind the faceplate and/or on the edge of the circuit board. Make sure it doesn't damage the part you're trying to clean. If it's safe, start using the alcohol to clean the areas where dye remains.
Previous Topic: Your go-to "holder"
Next Topic: How Big Is Your Shop?
Current Time: Wed Nov 04 17:16:05 CST 2026
