Home » Audio » General » A Really Inexpensive Tweak
Re: A Really Inexpensive Tweak [message #962 is a reply to message #941] Wed, 13 October 2004 09:15 Go to previous message
I got one; I use these slate interior floor tiles supported by 3/4lb lead fishing weights, the tri-corner type placed on top of these cheap telephone pads. I put this contraption on top of all surfaces. The Lead weights stay in place pointy side up, the slate tiles are about 4"x4" and they sit on top of the fishing weights (or sinkers for you fresh water guys). I put the telephone pads under the sinkers to prevent scratching. Total cost, about 1$ per resonance sink. Another is Sears sells these rollar bearings made of teflon that sit in a teflon cup. They come in different sizes and work well under all CD or amp chassis. About 1$& 15c each.
The best one of all is using threaded rod and a cross brace to make a square frame. Then getting chair webbing and using the threaded rod: stretching the chair webbing taught, then sitting the component on top of the stretched web; total isolation.(Sounds like Americas current foriegn policy) J.R.
Previous Topic: A Semi-Audio-Related Question
Next Topic: Rocky Mountain Audio Fest. Next Week in Denver
Current Time: Sat Nov 07 16:43:09 CST 2026
