Home » Audio » Thermionic Emissions » Has anyone used the 6CK4 as an output tube?
Has anyone used the 6CK4 as an output tube? [message #9605] Thu, 23 March 2006 13:18 Go to next message
Here is an intersting amplifier schematic on Kevin Kennedy's website.
I like the looks of this design from a simplistic viewpoint.
But, I am not sure about the use of a 12AU7 as the front end and phase slitter though.
Anyone with experience to share about this vacuum tube and possible amplifier circuits, will be greatly appreciated?
Thanks
Norris Wilson
Link? Sorry! [message #9606 is a reply to message #9605] Thu, 23 March 2006 13:20 Go to previous messageGo to next message
My bad memory forgot again.
Here is the link:
can't bee that hard...:) [message #9607 is a reply to message #9606] Fri, 24 March 2006 11:48 Go to previous messageGo to next message
Hey-Hey!!!,
It is after all a triode. Pick a load 4x the plate Z, keep it within dissipation limits, and even if you go PP, set the B+ so it remains Class A.
Should be better than the triode strapped 6V6, and plate ratings are similar...:) It's better( IMO ) to use a single-grid valve if you want a triode. Triode strapped pentodes seem a 2nd choice to me in comparison.
cheers,
Douglas
Re: can't bee that hard...:) [message #9617 is a reply to message #9607] Sun, 02 April 2006 20:12 Go to previous messageGo to next message
DIY audio has a whole thread on building an amp out of this tube. With schematic and pictures.
Cool, thanks! (nt) [message #9618 is a reply to message #9617] Mon, 03 April 2006 12:10 Go to previous messageGo to next message
nt
Re: Has anyone used the 6CK4 as an output tube? [message #9697 is a reply to message #9605] Sun, 25 June 2006 16:58 Go to previous message
dividebytube is currently offline  dividebytube
Sound Practices had a schematic for a PP amp using a 12BZ7 driver - I was always planning to build one of these using a Kepco power supply - just to check it out...
Previous Topic: Can Someone suggest a good book on S.E.T.'s.
Next Topic: Convertible
Current Time: Mon Nov 04 14:39:55 CST 2024
