Home » Audio » Measurement » Crossover slopes (for old subs)
Re: Crossover slopes [message #95948 is a reply to message #95947] Tue, 30 August 2022 13:46 Go to previous messageGo to previous message
It's really just a guess without measurements. But it does sound like they intended to run the subwoofer up pretty high to match their mains. So it might just work as a flanking sub.
One thing you can do without measurements is to run the sub by itself and listen. If it sounds like you can hear muffled vocals, then there is some energy in the region we blend with mains to reduce SBIR and higher modes. That's the purpose of flanking subs. So if you hear that, they may just work for you!
Previous Topic: Crossover optimization for DI-matched two-way speakers
Next Topic: aX IEC 60268-5 replacement article
Current Time: Thu Nov 05 13:45:34 CST 2026
