Drapes or Curtains [message #89165] |
Mon, 12 November 2018 04:56  |
Jethro
Messages: 48 Registered: November 2018
Baron |
I know that drapes absorb more sound than curtains. What do you think about which one will help produce a better sound quality for room acoustics?
Re: Drapes or Curtains [message #95833 is a reply to message #89165] |
Thu, 14 July 2022 07:39   |
Curry
Messages: 10 Registered: May 2022
Chancellor |
The difference is not substantial with drapes or curtains. I see some theatres use both. There are other considerations like the wall paneling, furniture, and flooring since everything in the room will want a share in the good distribution. There will be much more done to a room to bring in the quality of a theatre.
Re: Drapes or Curtains [message #95841 is a reply to message #95833] |
Fri, 15 July 2022 21:12  |
gofar99
Messages: 2005 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, It seems that the question is what do you think is not as good as it ought to be? Second what is the room like now in terms of construction (wood, brick, cement..) what is the size, shape and contents? All these things will alter the sound. I suspect that just window coverings will not do the whole job, especially if you have hard, flat surface walls. Let us know and we will see if we can come up with some ideas.
