Home » Sponsored » Pi Speakers » 4 Pi Build in San Luis Obispo - Flush Mounting and Bracing
Re: 4 Pi Build in San Luis Obispo - Questions for Wayne [message #95583 is a reply to message #95582] Tue, 03 May 2022 14:43 Go to previous messageGo to previous message
Some questions for Wayne.
1) Ok to use foam or wax strips for gaskets? I have a bunch from other projects.
2) Waveguide is recessed. Does it require "more meat" (backing) like the woofer)?
3) Can I install a larger piece for bracing?
- I was thinking of installing a more substantial piece of bracing that would touch all 4 interior walls, add more support, and give me something to attach the insulation to.
4) I have added some backing behind the woofer. I may add backing behind the waveguide. I would also like to potentially add the bracing that I described above. At what point should I be concerned about having a material impact on the internal volume.
5) I did see your article about how to properly install T-Nuts however I am wondering if it is ok to simply use larger wood screws in place of t-nuts especially because I used plywood as the backing for my woofers?
Previous Topic: 3Pi plans and questions
Next Topic: 3Pi Plans
Current Time: Fri Nov 13 04:02:02 CST 2026
