Re: My 3π adventure [message #95566 is a reply to message #95565] Sat, 30 April 2022 14:03 Go to previous messageGo to previous message
hudelson2 wrote on Sat, 30 April 2022 13:30
I think you mean 50 millimeters or 5 centimeters, which is about 2 inches.
Of course you're right, sorry about that.
The waveguides are done! Here is a picture and I will post some measurements when I do find the time to do them. They look way better up close, it's very difficult to photograph reflective surfaces.
/forum/index.php?t=getfile&id=3034&private=0
In other news I have gathered everything that's needed except the insulation. I have also tested the mounting hardware, the tnuts go into the wood very easily if you use an Allen head screw. I was trying with Philips before that and it was very hard to do. Some common epoxy will probably stick them fine, I don't thing there's a need for expanding glue. I will contact the cabinet maker when I finish with the plans and move on from there.
  • Attachment: _DSC3254.jpg
    (Size: 1.07MB, Downloaded 1299 times)
Next Topic: 7 Pi plans
Current Time: Tue Oct 20 23:13:30 CDT 2026
