| Good enough smart TV [message #95360] |
Thu, 10 March 2022 05:52  |
Madison
Messages: 347 Registered: June 2017
Grand Master |
I know that a good rule of thumb is that you get what you pay for, and that's fine, but I'm just looking for a large smart TV that's good enough. It will be placed in a classroom like setting, where older kids will be frequent users and handlers of the machine. If this TV doesn't get wrecked, then I'll look into getting them something nicer later on. Any suggestions?
| Re: Good enough smart TV [message #99137 is a reply to message #95360] |
Sat, 13 December 2025 11:07  |
Prince
Messages: 121 Registered: September 2025
Master |
Since the TV that you want has to do with older kids, I will suggest that you also get a wall mount that is going to keep the TV out of reach of the kids.
As for the TV, I will suggest you check out the TCL QM7K 75-inch size which sells for $1200 on Amazon. It has 4 HDMI 2.1 ports, Google TV, and 144Hz with VRR for fluid playback. This is the size that they are using at the school that my stepson goes and it has been in use for a while according to his teacher. So, since you want something that will last for a long time, this is the one you should get.
