Home » Audio » Home Theater » Whistling noise?
Whistling noise? [message #95090] Tue, 18 January 2022 08:32 Go to next message
LCallan is currently offline  LCallan
My projector has started making a high-pitched whistling noise that is incredibly annoying. Googling the issue keeps brining up tinnitus, but I'm certain that I don't suffer from that problem, since I only hear the noise when I'm using the projector. I've had the projector for about five years. Is it simply wearing out?
Re: Whistling noise? [message #95093 is a reply to message #95090] Thu, 20 January 2022 11:45 Go to previous messageGo to next message
Does the whistling noise start once you've been running it a while? Maybe it's overheating. Make sure that air can circulate around it. Modern projectors generally have a decent lifespan. It mostly depends on how often you use it.
Re: Whistling noise? [message #95095 is a reply to message #95090] Thu, 20 January 2022 15:13 Go to previous messageGo to next message
It happens all the time. As soon as I start it up, the whistling starts. I can't watch anything with it. The whistling is that irritating. I asked my dad to check it out, but he can't hear it. I guess it's too high-pitched.
Re: Whistling noise? [message #95179 is a reply to message #95095] Thu, 03 February 2022 15:38 Go to previous messageGo to next message
I'm sorry that I didn't get back with you sooner, LCallan. It could be a blocked vent. Look at your manual and see if tells you how to remove the vent cover. If not, try a site like Fixya. Clean it out and see if that does the trick.
Re: Whistling noise? [message #95245 is a reply to message #95090] Tue, 15 February 2022 09:33 Go to previous messageGo to next message
Yeah, I'm with Strum Drum, I think you're dealing with a blocked vent. Is your projector mounted to the ceiling? That's a convenient spot to put it to save room, but you have to make sure that cool air can circulate around it.
Re: Whistling noise? [message #99033 is a reply to message #95090] Fri, 24 October 2025 11:41 Go to previous messageGo to next message
Helen is currently offline  Helen
The causes of whistling noise in a projector can be blocked air vents or poorly sealed panels. I had experienced it while in school when we are using it for our projects and research. We get to call a technician because it wasn't something we can do on our own. he cleaned the fan and also change the power board.
Re: Whistling noise? [message #99292 is a reply to message #99033] Mon, 16 March 2026 23:27 Go to previous message
Prince is currently offline  Prince
Helen wrote on Fri, 24 October 2025 11:41
The causes of whistling noise in a projector can be blocked air vents or poorly sealed panels. I had experienced it while in school when we were using it for our projects and research. We get to call a technician because it wasn't something we can do on our own. he cleaned the fan and also changed the power board.
Hanging projectors on the fan is one major cause of such situation and if you've got someone who's got an idea on projectors installation, then there won't have been need calling a technician since it is a simple job that anyone who's got an experience can handle.
Previous Topic: Know before you buy
Next Topic: Surround Sound
Current Time: Wed Nov 04 22:00:24 CST 2026
