Home » Audio » Speaker » Combo B&C DE250 with Altec 811 (cross over design around 800 Hz / 1 Khz )
Combo B&C DE250 with Altec 811 [message #95094] Thu, 20 January 2022 13:29 Go to next message
Arthur C is currently offline  Arthur C
Hi,
May I kindly request some help or fed back concerning a crossover design.
Does a member has already tried the combo B&C DE250 With Altec 811B
I am planning to build a new 2 way configuration a speaker between Klipsh Cornwall and 4 Pi speaker.
The idea is to us a 96 dB 15' carbon fiber woofer (Davis acoustic speaker 40 RCA15 DF) with Altec 811 B horn ad B&C DE250 compression driver.
A 1k6 cutoff frequency seams not appropriate for my woofer, a 800 HZ cut off should be great in a 12db/18db configuration.
According to Wayne's documentation the crossover should be as follows:
- Concerning the woofer : Zobel : 8 ohms + 22 UF capacitor
L2 : 2.00 MH
C4 : 20 UF
- Compression driver and horn :
C2 : 16 UF
L1 : 1.2 mH
C3 : 47 UF
R1 = 20 ohms
R2 = 14 ohms
C1 = 1.6 uF.
Concerning C1 : a reduce capacitor should flatten the frequency response ?
Should high frequencies have to be boost I could add a super-tweeter
May I kindly ask you if this configuration could be accurate ?
Any proposal will be welcomed.
Re: Combo B&C DE250 with Altec 811 [message #95096 is a reply to message #95094] Thu, 20 January 2022 17:02 Go to previous messageGo to next message
The Altec 811 creates a pattern that narrows as frequency rises. So it shouldn't use the same kind of crossover. Specially, the values for R1, R2 and C1 won't be appropriate for the 811. A straight attenuator or L-Pad is going to be more suitable.
Re: Combo B&C DE250 with Altec 811 [message #95097 is a reply to message #95096] Fri, 21 January 2022 07:36 Go to previous messageGo to next message
Hi Wayne,
Many thanks for your feedback and your explanations.
Then in my understanding, I can keep the upon mentioned crossover and substitute a L-Pad to the other ^part of th circuit.
Just one little question, would it be possible to compensate the trembles.
Many thanks best regards;
Re: Combo B&C DE250 with Altec 811 [message #95100 is a reply to message #95097] Fri, 21 January 2022 09:14 Go to previous messageGo to next message
That's right. You don't need the response modification created by R1/R2 and C1 because they provide equalization for mass-rolloff, which is acoustically equalized by the collapsing directivity of the Altec horn. So use an L-Pad instead.
You can, of course, provide any other sort of (active or passive) equalization to suit your taste.
Re: Combo B&C DE250 with Altec 811 [message #95119 is a reply to message #95100] Mon, 24 January 2022 12:23 Go to previous messageGo to next message
Wayne,
Many thanks for your feedback and clarification.
I have built a 4Pi Speaker which works very well. A very nice speaker.
My new project with a 15' carbon fiber woofer is not really suitable for a frequency cut off too high.
I will review my crossover concerning the Altec 811.
I have seen a nice horn (very cheap) that should be nice also.
https://sono.e44.com/sonorisation/haut-parleurs/haut-parleurs-autres-marques/pavillon-abs-moteur-sono-465-245mm-MHD5P.html
Many tanks for our help.
Best regards.
Arthur.
Re: Combo B&C DE250 with Altec 811 [message #95120 is a reply to message #95119] Mon, 24 January 2022 14:54 Go to previous messageGo to next message
Arthur,
One important detail; the B&C DE250 isn't intended to be used down to 800Hz.
Altec drivers would be one option if that x-over frequency is required for your
chosen woofers. Another would be to build a 7-Pi type design with the 811's
and the Pi midhorn. That arrangement was very satisfying for me, although
I've since built proper 7-Pi's with Wayne's horn and crossover instead.
Chris
Re: Combo B&C DE250 with Altec 811 [message #95284 is a reply to message #95120] Tue, 22 February 2022 08:21 Go to previous messageGo to next message
Dear Wayne,
Just one little question.
You have published the frequency response of Altec 811 + PSD.
I think that frequency response should be nearly the same with DE 250.
In your publish frequency response with 1.6 K filter.
For your test do you have used the 4pi speaker cross over with "Pi" compensation ?
I have already made a 4pi speaker and I would like to substitute the horn by the Altec 811.
Best regards.
Re: Combo B&C DE250 with Altec 811 [message #95285 is a reply to message #95284] Tue, 22 February 2022 09:24 Go to previous message
I measured the 811 horn (on-axis) with a variety of networks. You'll notice the ones without CD compensation had response that was nearly flat or just slightly falling as frequency rises. Both are pretty natural sounding. The ones with CD compensation showed response that was rising, and they sounded a little too bright.
Previous Topic: 2 pi's
Next Topic: Ideas for large shop
Current Time: Mon Aug 26 00:13:45 CDT 2024
