Home » Audio » Measurement » Measuring through earbuds
Measuring through earbuds [message #94990] Thu, 23 December 2021 19:34 Go to next message
Mica is currently offline  Mica
How can you measure how loud noise is when it is coming through earbuds? I'm afraid that even though the music isn't at full blast, it's too loud for my children. I want a way to measure it.
Re: Measuring through earbuds [message #95013 is a reply to message #94990] Thu, 30 December 2021 18:33 Go to previous messageGo to next message
LCallan is currently offline  LCallan
You can measure the loudness with a decibel meter. They're fairly inexpensive to acquire on Amazon. However, a quick trick is to hold the earbuds at arm's length with their music playing as usual. If you can still easily hear the music, then you know it's too loud for them.
Re: Measuring through earbuds [message #95151 is a reply to message #94990] Sun, 30 January 2022 11:10 Go to previous messageGo to next message
I only use buds for softer music, podcasts, etc..... Since they are in my ear and that close to the drum, I don't want to damage anything and I don't want to totally drown out the outside noises.
Re: Measuring through earbuds [message #95309 is a reply to message #95013] Sat, 26 February 2022 03:43 Go to previous messageGo to next message
Silver is currently offline  Silver
LCallan wrote on Thu, 30 December 2021 18:33
Do they make decibel meters with "ports" in them that look like ear openings to put the buds into? That would be a very accurate way of doing it.
If not, maybe they should. And maybe I just invented something.
(Saving post for proof of idea)
Re: Measuring through earbuds [message #95478 is a reply to message #94990] Mon, 04 April 2022 08:46 Go to previous messageGo to next message
Zart is currently offline  Zart
Usually, there would be a warning that would pop on your screen when the volume is too loud. You can use that, in general, as the minimum level, then decrease the sound from that if you think it's still too much.
Re: Measuring through earbuds [message #99079 is a reply to message #95478] Thu, 06 November 2025 12:13 Go to previous messageGo to next message
Becky is currently offline  Becky
That’s a good question! You can use a free decibel meter app on your phone, just put one earbud close to the phone’s mic and play the music at its usual volume. It won’t be exact, but it gives a rough idea. Safe listening is usually under 85 dB, so if it’s louder than that, it’s best to turn it down. Some phones also have built-in volume limit settings you can use for kids.
Re: Measuring through earbuds [message #99243 is a reply to message #94990] Sun, 22 February 2026 23:40 Go to previous message
Prince is currently offline  Prince
Measuring the noise can be done in many ways, but the ones that I would suggest you do are these two methods.
The first one is what I call the talk test. You need to talk when you are standing a few metres away from them. If they are unable to hear you easily, then you need to reduce the volume.
The second one is what some have suggested already which is using a phone app like the NIOSH sound level meter.  You measure this by placing the phone mic right against the earbud cup to measure. The aim should be around 75 dB which is ideal for kids. Once you get the measurement right, you won't have anything to worry about anymore.
Previous Topic: Bluetooth audio measurement
Next Topic: Linear measurements in audio gear
Current Time: Thu Nov 05 04:23:43 CST 2026
