Home » Audio » General » Really Tweaking The EQ.
Really Tweaking The EQ. [message #94964] Sat, 18 December 2021 14:08 Go to next message
Miami is currently offline  Miami
Are there equalizers that let you save different settings on different songs, so whenever you go back and play them again, they are all set to their different adjustments? Most people I know just adjust the settings for how they like to hear their music, but I like to get more detailed and adjust settings for every song I have because they are all different in different ways.
Pink Floyd vs. AC/DC. George Strait vs. Blackberry Smoke. For instance.
Re: Really Tweaking The EQ. [message #94967 is a reply to message #94964] Sat, 18 December 2021 17:02 Go to previous messageGo to next message
Probably in the digital domain. Don't know any. I'm analog oriented.
Re: Really Tweaking The EQ. [message #94977 is a reply to message #94967] Mon, 20 December 2021 20:39 Go to previous message
Hi, Not exactly...however something like the Behringer DEQ2496 I have will allow you to store a bunch of eq curves. So all you would need to do is select the one you want for each type of music. It allows you to label each curve so there would not be a lot of confusion. The down side is the units are not cheap and will need to be inserted into the signal chain. Usually this is between the preamp stages and power output ones. So...if you use anything but a serious stereo system this option won't work for you.
Previous Topic: That Tree In The Forest
Next Topic: Anyone snag a good AV deal?
Current Time: Sat Nov 21 23:16:53 CST 2026
