Home » Audio » Thermionic Emissions » Identical gain & tonality in double-triode tubes (ECC82)  () 1 Vote
Re: Identical gain & tonality in double-triode tubes (ECC82) [message #94910 is a reply to message #94909] Tue, 14 December 2021 01:08 Go to previous messageGo to previous message
kasperbergholt wrote on Mon, 13 December 2021 10:52
Dear tablers,
Inspired by the excellent feedback (e.g. on the E80 CC tube having quite different specs from the ECC82) the I got in this thread:
https://audioroundtable.com/forum/index.php?t=msg&th=23320&goto=94872&
some new questions have shown up in regards to gain levels for a single tube preamplifier like mine.
Which parameters determine the level og gain?
Some measurements are extremely detailed, e.g. this one from an eBay listing:
Sollwert IA [mA] fx 10,5 og 10,5
Messwert IA [mA] fx 10,012 og 9,945
= % vom Sollwer 95 og 95%
S (mA/V] 1,92 og 19,96
bei Deltage UG1 0,6 og 0m6
D Anode [%] 6 og 6,1
Messwer IA [mA] 7,2 og 7,13
bei UA [V] 225,08 og 225,08
Ri [KOhm] 9,1 og 9
A different listing for a tube in the same price range is a lot more sparse:
ECC82 TELEFUNKEN ( 12AU7 E82CC CV400 ) # <> # NOS
gemessen auf RPM370
12 / 12 mA 100 % = 10,5 mA
Most list the mA values, few the Anode value.
In addition, is there a formula for calculating if the difference between values will be noticable e.g. in a 1 dB's difference in volume measured from 1 meter from the loudspeaker?
And, lastly, how about differences in tonality / frequency response. Are such inherent in the gains measurement (or other parameters)?
Thanks again,
Kasper
Hi Kasper,
There are a couple of ways to check for the gain of a stage.
One is: Av = -Mu x RL/rp + RL
Where Av is the gain
Mu is the mu of the tube.
RL is the plate resistor
rp is the plate resistance of the tube.
Another equation is: Av = -Gm x rp x RL/rp + RL
Gm is the transconductance figure.
Mu, Transconductance (Gm or ma/v), Plate Resistance (rp), and even the plate resistance (RL) varies some.
Altering the rp, RL, Av will affect the high frequency response. The extent will depend upon said values resistances, load resistance, and capacitances involved.
The cathode resistor (Rk) will provide negative current feedback, if not bypassed, which also affects the gain and frequency response (fr).
Hope this helps, cheers.
pos
Previous Topic: ECC 82 recommendation | Telefunken vs Mazda Belvu
Next Topic: Tubes from Russia
Current Time: Wed Sep 23 21:26:09 CDT 2026
