Home » Sponsored » Pi Speakers » 2Pi Tower Build  () 1 Vote
Re: 2Pi Tower Build [message #94647 is a reply to message #94173] Thu, 21 October 2021 11:58 Go to previous messageGo to next message
birkbott is currently offline  birkbott
This is all great advice, thanks!
Re: 2Pi Tower Build [message #94653 is a reply to message #94173] Fri, 22 October 2021 09:13 Go to previous messageGo to next message
One more question, is Douglas fir ok to use for the internal bracing or should I use hardwood as in the plans? I also have extra MDF on hand.
Re: 2Pi Tower Build [message #94654 is a reply to message #94653] Fri, 22 October 2021 09:46 Go to previous messageGo to next message
Any of those are fine for bracing. I'd use the MDF.
Re: 2Pi Tower Build [message #94662 is a reply to message #94173] Sat, 23 October 2021 12:02 Go to previous messageGo to next message
Thanks, another question, where's the best place to get unfaced R13 insulation? I can only find it faced in my area. Is it easy to remove the facing? Would it be ok to leave the facing on for the top/side/front parts of I remove it for the horizontal sections?
Re: 2Pi Tower Build [message #94663 is a reply to message #94662] Sat, 23 October 2021 13:22 Go to previous messageGo to next message
It's very easy to remove. Just peel it right off. Remove the backing from all sheets.
Re: 2Pi Tower Build [message #94720 is a reply to message #94173] Sat, 30 October 2021 13:41 Go to previous messageGo to next message
Before I put the backs on, how does this insulation look? I did top, one side, front wall up to the 2nd brace, and spanning the braces. Nothing goes on the bottom right?
/forum/index.php?t=getfile&id=2904&private=0
Re: 2Pi Tower Build [message #94728 is a reply to message #94720] Sun, 31 October 2021 08:58 Go to previous messageGo to next message
That's perfect.
Re: 2Pi Tower Build [message #94757 is a reply to message #94173] Sun, 07 November 2021 09:34 Go to previous messageGo to next message
Finished my towers today, in white duratex.
I did apply the logos after this photo, they sound great!
/forum/index.php?t=getfile&id=2908&private=0
Re: 2Pi Tower Build [message #94761 is a reply to message #94757] Sun, 07 November 2021 15:18 Go to previous message
That looks fantastic! Really good job!
It reminds me of my very first pair of one Pi speakers 'cause I painted 'em white just like that. That's for the chance to reminisce!
Previous Topic: 7pi build
Next Topic: 8 Pi Plans Please
Current Time: Mon Sep 21 06:01:21 CDT 2026
