Home » Audio » Thermionic Emissions » Pinging MQracing
Re: SE - Copper would be cool! [message #9452 is a reply to message #9449] Wed, 21 December 2005 21:33 Go to previous messageGo to previous message
Steve Eddy is currently offline  Steve Eddy
I've never seen smooth seams when plastic welding. It's basically just a small diameter heat gun used to melt plastic rod that is fed into the seam.
Basically like a hot glue gun except you use hot plastic, yes?
SE --- Copper would be cool!
*grumble* *grumble* *grumble*
se
Previous Topic: New Millett Hybrid Done!
Next Topic: Douglas, Damir, I did some more work on the 300bPP amps
Current Time: Tue Nov 03 07:29:15 CST 2026
