Home » Audio » Thermionic Emissions » Pinging MQracing
Re: Pinging MQracing [message #9450 is a reply to message #9444] Wed, 21 December 2005 21:15 Go to previous messageGo to previous message
Steve Eddy is currently offline  Steve Eddy
I really like the light/white look of the mounting panel behind the darker wood when looking through the holes on your prototype.
Actually that part IS plastic.
It's the Delrin shoulder washers used for isolating the connectors and their diameter is virtually the same as the diameter of the through holes that the connectors are protruding through.
I could have just mounted the RCAs without them but the diameter of the shoulder on the shoulder washer was 3/8" and the diameter of the threads on the RCA were some metric dimension so I just made it simple and drilled 3/8" holes.
se
Previous Topic: New Millett Hybrid Done!
Next Topic: Douglas, Damir, I did some more work on the 300bPP amps
Current Time: Tue Nov 03 07:29:12 CST 2026
