4pi build with stands finally realized [message #94409] Sat, 11 September 2021 19:19 Go to previous message
Started planning and buying parts a year ago, and now it is time to create them. I have spent some time with Sketchup to try different designs. They are made of 21mm plywood with double baffle and additional bracing. Finishing will be bare plywood with Osmo black wax. Internal measures, port dimensions and positioning of drivers are according to original spec. DE250 and JBL2226 drivers will be used. I am showing you pictures from sketchup in this first post. More pictures from the build process will be shared tomorow.
/forum/index.php?t=getfile&id=2814&private=0
/forum/index.php?t=getfile&id=2815&private=0
/forum/index.php?t=getfile&id=2816&private=0
/forum/index.php?t=getfile&id=2817&private=0
  • Attachment: 4pi_1.jpg
    (Size: 340.15KB, Downloaded 1712 times)
  • Attachment: 4pi_2.jpg
    (Size: 488.68KB, Downloaded 1746 times)
  • Attachment: 4pi_3.jpg
    (Size: 503.51KB, Downloaded 1670 times)
  • Attachment: 4pi_4.jpg
    (Size: 224.72KB, Downloaded 1618 times)
Current Time: Tue Sep 29 21:20:50 CDT 2026
