Home » Sponsored » Pi Speakers » 8 years later
Re: 8 years later [message #94290 is a reply to message #93455] Fri, 20 August 2021 12:27 Go to previous messageGo to previous message
Making sawdust and screwing up Embarassed Embarassed Embarassed
I fucked up when I picked up wood and didn't figure it out til too late, really nice quality Finnish Birch ply... but accidently bought 0.8267" instead of 0.75" thickness. The only panel I haven't glued in is the speaker baffle.
Options:
1/ The baffle that I've already cut fits in between the sides. It will however make the enclosure 2.5L/0.09ft3 smaller than in the plans. Should I change the port length so it get's back to the original 37Hz tuning or is that a pointless endeavour?
2/ Buy a bit more wood and cut a new one that will fit on the sides. That will make the cabinet 4.5L/0.16ft3 bigger than in the plans. The extra volume I can use for extra bracing.
But does the extra 2.1cm/0.82 inch the woofer will be closer to the corner make a negative difference?
Best regards
Ben
Previous Topic: Older 4 Pi speakers
Next Topic: Cornerhorns - what corners are "good enough"?
Current Time: Sat Nov 28 14:44:06 CST 2026
