Home » Audio » Pro Sound » Best Headphones?
Best Headphones? [message #94071] Wed, 21 July 2021 00:02 Go to next message
Raymond is currently offline  Raymond
I'm looking to buy a pair of headphones for my sister as a birthday gift. She's had Skullcandy for a while, but she isn't impressed with that brand overall and she's looking to change it up. Does anyone have a recommendation?
Re: Best Headphones? [message #94077 is a reply to message #94071] Wed, 21 July 2021 13:11 Go to previous messageGo to next message
This guy is a knowledgeable reviewer. Testing many of the products himself. There's a good number of headphones he's reviewed on this site. Some quite expensive, but there are reasonable priced ones also. This might give you some good knowledge on what to look for.
https://kenrockwell.com/audio/index.htm
Re: Best Headphones? [message #94263 is a reply to message #94071] Wed, 18 August 2021 00:48 Go to previous messageGo to next message
Acacia is currently offline  Acacia
​You can look into Sony for headphones, although most of their products also have a good reputation. The quality can change depending on the model since the specs will vary. It's better to know what features she's looking for in a good headphones.
Re: Best Headphones? [message #94383 is a reply to message #94071] Mon, 06 September 2021 03:04 Go to previous messageGo to next message
Phonetic Ear is currently offline  Phonetic Ear
Does your sister travel a lot? It's something to consider because there are headphones that are easier to carry around more than others. Aside from the brand, look into the specs such as battery life and noise-canceling ability.
Re: Best Headphones? [message #94730 is a reply to message #94071] Sun, 31 October 2021 15:55 Go to previous messageGo to next message
LoveJB is currently offline  LoveJB
Noise canceling is key! Does she want wireless or wired? We bought a pair of JBL headphones last year and I have to admit that they are great! I did not really even know the brand when we bought them.
Re: Best Headphones? [message #99356 is a reply to message #94730] Fri, 17 April 2026 00:00 Go to previous messageGo to next message
Clint is currently offline  Clint
LoveJB wrote on Sun, 31 October 2021 15:55
Any headphones made in this era that don't have the noise cancellation feature is as good as nothing. I mean that feature makes a whole lot of difference especially for those who makes use of the headphone in the studios. I've used some headphones from JBL in the past and must say that they are very good at what they do.
Re: Best Headphones? [message #99357 is a reply to message #99356] Fri, 17 April 2026 09:19 Go to previous message
Since noise-cancelling headphones inherently modify the sound - by design - they interfere with the source material.
Not saying that as an attack, merely a point of fact.
So my thought is that noise-cancelling headphones are kind of like MP3 players.  They provide an advantage that is not fully compatible with highest fidelity but that makes an attractive trade-off.  Noise-cancelling headphones can sound nearly as good as purely analog passive headphones, and they also reduce ambient noise.
Active noise cancellation (ANC) creates "anti-noise" waves to counteract external sounds, the process involves an additional layer of digital signal processing (DSP) that can sometimes interfere with the pure audio source.  They do so by digitizing the music, applying a filter to add the anti-noise, and then converting it back to analog. This extra step can introduce minor distortions and artifacts.
Some listeners notice a faint electronic "hiss" when ANC is engaged in quiet rooms, which is caused by the electronics themselves. And cancellation waves are most effective at low frequencies. This focus can inadvertently alter the bass response, sometimes making it feel thinner or artificially boosted by the manufacturer to compensate.  ANC headphones also tend to create an artificial soundstage, reducing the perception of depth and space.
Previous Topic: Earphone Recommendations?
Next Topic: Should I blow the budget on getting expensive cables?
Current Time: Sat Nov 21 12:09:48 CST 2026
