Home » Sponsored » Pi Speakers » Smaller 3 pi construction?
Re: Smaller 3 pi construction? [message #93842 is a reply to message #93841] Mon, 31 May 2021 09:47 Go to previous message
I've seen that white residue from adhesive too. It's really common from super glue.
As for the port, it won't change the SPL significantly but it does change the possibility of a pressure node lining up with it. Of course, if you're changing box dimensions, you'll need to check the lower midrange anyway, so that's just part of it.
Previous Topic: Old pi 4?? Trying to find info about these speakers
Next Topic: Woofer to add with 2pi
Current Time: Thu Sep 24 23:10:39 CDT 2026
