Home » Sponsored » Pi Speakers » 1pi port and insulation
1pi port and insulation [message #93678] Sat, 08 May 2021 09:41 Go to next message
Good morning. I have a problem with the insulation standing up into the port area. Is it possible to fix this somehow? Thank you
Re: 1pi port and insulation [message #93679 is a reply to message #93678] Sat, 08 May 2021 10:36 Go to previous messageGo to next message
I use R11/R13 and it doesn't overlap the port on a one Pi cabinet. It just lines the interior walls, specifically the rear, bottom and side nearest to the port. You kind of have to "tuck in" the side and bottom sheets beside the port.
Is that what is happening in your situation? Are you using sheets of fiberglass insulation or something else?
Re: 1pi port and insulation [message #93680 is a reply to message #93679] Sat, 08 May 2021 10:57 Go to previous messageGo to next message
It is tucked in but seems really fluffy and thus sticks up into the port area. I built these forever ago and it's always been this way. Thanks for the help.
Re: 1pi port and insulation [message #93681 is a reply to message #93680] Sat, 08 May 2021 11:27 Go to previous message
If it's just bulging where it meets the port, it's fine. That's to be expected.
Previous Topic: 2pi 1pi crossover
Next Topic: four Pi and subs
Current Time: Sun Oct 25 13:37:06 CDT 2026
