Home » Sponsored » Pi Speakers » Flat-Pack Kits!
Flat-Pack Kits! [message #91511] Sat, 29 February 2020 15:56 Go to next message
I am pleased to announce that Pi Speakers now has flat-pack kits!
We have flat pack kits for one π, two π, three π and four π models, as well as the three π subwoofer.
We also have the midhorn available as a flat-pack kit and have for many years. It's in the "Parts And Options" section of the shopping cart.
Each flat-pack kit contains pre-cut parts to build one loudspeaker cabinet. So if you want a stereo pair, order two. If you order two kits, we'll assume you want a mirror-image pair, and will ship one cabinet with the port on the left and one with the port on the right.
If you only order one speaker, please mention the desired port side in the notes section of the order. If you order three speakers and want the center channel sans-port with waveguide centered, mention that in the notes. We can do that too. But don't do a port delete on a stereo pair. They work best vented as designed, and only a center channel should be considered to be run sealed when it is used with vented right and left mains.
If you want to veneer the cabinet, apply the veneer after assembling the cabinet with the MDF panels. That ensures best quality. We considered offering veneered panels as an option, but the edge quality is better if the cabinet is completed before applying the veneer.
Re: Flat-Pack Kits! [message #92054 is a reply to message #91511] Sun, 21 June 2020 10:26 Go to previous messageGo to next message
Hi Wayne,
Are the Four Pi flat packs MDF or another kind of wood?
Happy Father's Day!
Thanks,
Alex
Re: Flat-Pack Kits! [message #92055 is a reply to message #92054] Sun, 21 June 2020 17:31 Go to previous messageGo to next message
The flat packs are made of MDF.
Re: Flat-Pack Kits! [message #92221 is a reply to message #91511] Thu, 27 August 2020 10:48 Go to previous messageGo to next message
Does the flat pack come with a board to mount the crossover on or does the PCB mount directly to the cabinet with standoffs? What is the recommended way?
Any updates planned for the Pi 4 or anything come down the pike? Very Happy
Re: Flat-Pack Kits! [message #92230 is a reply to message #92221] Fri, 28 August 2020 10:26 Go to previous message
I like to mount the crossover board directly on the bottom cabinet panel with a gasket underneath:
Previous Topic: Finish up a pair of 4pis
Next Topic: Four Pi C3 & C5
Current Time: Wed Sep 16 19:49:01 CDT 2026
