Home » Sponsored » Pi Speakers » 7pi build
Re: 7pi build [message #93420 is a reply to message #93419] Thu, 01 April 2021 19:07 Go to previous messageGo to previous message
The side panels are longer since their angle is greater. When I did the original prototypes, I cut them as shown in the plans. Later, the cabinet shop made a 3D model for cutting the panels and a jig for assembly.
None of that really helps much. What I suggest is that you make the top and bottom panels long enough they match the side pieces. The final result should be a horn that has 12" x 24" mouth and 4.5" square throat.
Previous Topic: 6Pi Build Approaching
Next Topic: 2Pi Tower Build
Current Time: Mon Nov 09 20:22:04 CST 2026
