Home » Sponsored » Pi Speakers » 7pi build
Re: 7pi build [message #93419 is a reply to message #93397] Thu, 01 April 2021 17:55 Go to previous messageGo to previous message
grimberg is currently offline  grimberg
Wayne,
While working on the mid-horns I ran into a problem. After cutting one horizontal side and one vertical side using the measurements in the documentation, I realized they do not align properly. After making sure my layout was correct, I decided to calculate the lengths of the sides using the length of the bases and associated heights. My calculations showed the length of the sides on the horizontal piece at 14.70", while on the vertical piece they measure 14.98", a bit shy of 9/32". Has there been an update to the documentation since you sent me a copy? Should the horizontal side made longer to match the length of the vertical side, or vice-versa?
Previous Topic: 6Pi Build Approaching
Next Topic: 2Pi Tower Build
Current Time: Mon Nov 09 20:21:55 CST 2026
