Home » Audio » Craftsmen » Creating a Projector at Home
Creating a Projector at Home [message #93198] Tue, 23 February 2021 12:14 Go to next message
Souldude is currently offline  Souldude
It's been a while since we can visit theaters and I've been missing the experience of watching in it. This gave me the thought of making a projector at home but I'm not sure where to start. Has anyone tried making it at home? How was the experience using it?
Re: Creating a Projector at Home [message #93205 is a reply to message #93198] Wed, 24 February 2021 15:19 Go to previous messageGo to next message
I created a theater room with dark paint, theater seats, and such. I made the "screen" by painting the wall white and framing it in with black paint. It looks pretty nice. I didn't make the projector itself, though. You should go for it.
Re: Creating a Projector at Home [message #93327 is a reply to message #93205] Wed, 17 March 2021 00:14 Go to previous messageGo to next message
Leot55 wrote on Wed, 24 February 2021 15:19
Thanks, man. One of my worries was the movie not becoming clear enough when projected because of the background. This gives me an idea about how I should set up my "theater" now.
Re: Creating a Projector at Home [message #93426 is a reply to message #93198] Sun, 04 April 2021 07:18 Go to previous messageGo to next message
Sounds like getting the room set up is the easy part. How does one "make" a projector"?
I'm pretty sure they sell projectors. This would be a great family get together idea.
Re: Creating a Projector at Home [message #93444 is a reply to message #93198] Thu, 08 April 2021 11:44 Go to previous messageGo to next message
Acacia is currently offline  Acacia
If it's the projector itself, I think it'll require some technical skills. In that sense, it could be better to buy one if there's a higher chance of messing with the parts and stuff.
Re: Creating a Projector at Home [message #98856 is a reply to message #93444] Wed, 01 October 2025 13:03 Go to previous messageGo to next message
Becky is currently offline  Becky
I haven't tried to set up a projector before or have the knowledge of doing so but for a projector to be set up in a room, some technical skills are needed. Calling a technician to set it up will make it easier without spoiling any parts of it.
Re: Creating a Projector at Home [message #98963 is a reply to message #98856] Wed, 15 October 2025 00:54 Go to previous messageGo to next message
Helen is currently offline  Helen
I can't do everything by myself or have any reason to try things that I know that I never find passion in doing. Setting or creating a projector at home is what I've never done but if I wanted it, I will call an expert to do so for me.
Re: Creating a Projector at Home [message #99140 is a reply to message #93198] Tue, 16 December 2025 21:43 Go to previous message
Hank is currently offline  Hank
Souldude wrote on Tue, 23 February 2021 12:14
Hi,
I am making use of a projector that I constructed two years ago and must say it was one of the best decisions that I made.
The image quality is top-notch while the projector brings that home cinema experience.
To build this projector, I had to go beyond the basics by making use of an LCD panel, lenses, and an LED light source. I sourced most of these materials from Aliexpress since they offered a wide range of electronics and parts that one can use to make constructions at home.
Here are the items that I used:
The LCD panel and driver board which cost $150
The Lenses (that's the front and back Fresnel lenses, the projection lens, and the condenser lens) that I spent $60 on.
I made use of the 200W LED as a light source which I spent around $150 to get. Then the cooling fans that were gotten for $40. You need two back fans, 8 small LCD fans, and a dust filter for that.
I used the acrylic sheets for the frame since I wanted top quality. Got nuts, wires, epoxy, black vinyl wrap, threaded rods, a power socket, HDfury splitter, and some other minor items for the construction.
Building the projector took me around a week to finish because it involved handling each part of the construction with great caution.
If you are interested in making something like this and have the budget to do so because I think you need around 400 to $500 to get the items in the online marketplace. I can now break down the processes that it took for you.
Hank.
Previous Topic: Where do you look for ideas?
Next Topic: Projects for fun vs. saving money
Current Time: Mon Nov 16 06:49:36 CST 2026
