Home » Audio » Speaker » L pad (Reducing sensitivity )
L pad [message #93153] Sat, 20 February 2021 10:08 Go to previous message
I have a very elementary question for any crossover circuit experts...
I am under the impression that a single resistor in series with a loudspeaker can increase overall impedance but also alter/attenuate frequency response, where an L-pad configuration (r-1 series x r-2 parallel) will increase the impedance without changing F.R.
Is this generalization mostly correct?
I have an upcoming build where I am trying to pad down a large waveguide/CD combo (ME464/DCX464) from 111db sensitivity to 98db sensitivity (to closer match a jbl2226). Basically a two way speaker.
They will be hi-amped, so I'm not sure how critical it is, but I'd like to pad down the 8ohm compression driver anyhow to get a closer start and the additional noise floor reduction ...
I am referring to an increase in overall loudspeaker impedance to a decrease in its overall sensitivity, I'm not sure if that is correct or not.
Previous Topic: Line array
Next Topic: Horns
Current Time: Fri Nov 06 09:28:16 CST 2026
