Home » Audio » Home Theater » Projector Suggestions?
Projector Suggestions? [message #93095] Sun, 07 February 2021 22:29 Go to next message
penguin89 is currently offline  penguin89
I'm looking to do something different with living room and I've decided on a home theater projector. Smile I'm looking to spend at most 2000 dollars on this. Does anyone have a suggestion for which projector I should look into?
Re: Projector Suggestions? [message #93096 is a reply to message #93095] Sun, 07 February 2021 23:02 Go to previous messageGo to next message
KalebTheAudioGuy is currently offline  KalebTheAudioGuy
With 2000 dollars, you could get a pretty nice projector. This one from Best Buy is 2000 dollars, and it lets you play content in 3D. I don't have this one myself, so I can't personally vouch for it, but it has a lot of good reviews.
https://www.bestbuy.com/site/sony-home-cinema-vpl-1080p-hd-sxrd-projector-black/5368900.p?skuId=5368900
Re: Projector Suggestions? [message #93098 is a reply to message #93096] Mon, 08 February 2021 07:56 Go to previous messageGo to next message
I like the Epson 4010 and use it fairly often. It was a snap to set up and it casts a vibrant picture. It doesn't overheat and you can actually store the settings you choose which makes it easy to move from room to room. It's been out for a while so you should be able to get it for a decent price.
Re: Projector Suggestions? [message #93451 is a reply to message #93095] Fri, 09 April 2021 10:42 Go to previous message
Souldude is currently offline  Souldude
You can check out ViewSonic's projectors. It has a lot of features that can even be used for gaming. Some can produce vivid images that can even withstand the light in the room. I'm sure you'll be able to get a good one with your budget.
Previous Topic: Simple DIY Home Theatre setup
Next Topic: Streaming or DVD.
Current Time: Wed Nov 04 02:08:42 CST 2026
