Home » Audio » Thermionic Emissions » Need power supply schematic for Merlin amplifier?
Thanks Damir and Douglas, I have- [message #9306 is a reply to message #9300] Tue, 01 November 2005 05:41 Go to previous messageGo to previous message
-a couple of Hammond 273X transformers that are rated at 350-350 and 110 mA. Will these make it in the ball park when using the 6V6 as an output tube? I am not sure how much current will be needed for good headroom and regulation.
I will play around with the Duncan power supply program to see what I can work out.
Do you have any sugestions about a good low impedance choke that will not eat up to much current? Also could use some give me some recommendations for rectifiers? My thought of a rectifier would be a Cree Shotkey type if I would need to use solid state because the power transformers voltage is too low.
Thanks for all of your help
Norris Wilson
Previous Topic: Ping: Speakerman57
Next Topic: Inexpensive Used PP EL84 Recommendations, please
Current Time: Fri Oct 30 23:29:24 CDT 2026
