Home » Audio » Thermionic Emissions » Inexpensive Used PP EL84 Recommendations, please
Re: Inexpensive Used PP EL84 Recommendations, please [message #9297 is a reply to message #9296] Mon, 24 October 2005 18:24 Go to previous messageGo to previous message
Hey-Hey!!!,
aside from enjoying it...what are your plans for the piece? Also, will you be needing just an amp? like a ST35 Dynaco? or some sort of integrated style?
The Dynaco SCA35 fits the integrated category, has the same output Iron as the ST35 and can be modified( probably require some re-fit for reliable day-to-day use anyway ).
The Heath W2 is a 6L6 amp, but has a 10k a-a output TX, and a seperate power supply, so a bit of work would be needed to fit El84. Mostly PS building, and socket swapping. It probably has better output Iron, but I am just speculating there...
And then there are the Eico and Scott to consider...
cheers,
Douglas
Previous Topic: Need power supply schematic for Merlin amplifier?
Next Topic: just in case you think 'going too far' is possible...
Current Time: Sat Oct 31 00:25:01 CDT 2026
