Home » Sponsored » Pi Speakers » which PI speaker to build
which PI speaker to build [message #92756] Sun, 13 December 2020 14:07 Go to next message
pittiplatsch is currently offline  pittiplatsch
Hello @all,
I plan to build a PI speaker to be used in a rather large and open living room (no corner placement). As this is my first DIY speaker project I would like to stay a bit on the budget constraint side for the first try (if possible). Somehow I settled for the 4 PI, but I would go for another model as well. That's basically my first question: is the 4 PI a good choice for my plans (listening condition in a large room and budget beginner project?) or are there better options.
Are there any upgrades I shall consider right from the start or is this something I could always do later on (e.g. upgrade drivers). Can the 4 PI also be build as a floor standing speaker to get a bit more bass extension?
you see - lots of beginner questions and thanks for your help.
Re: which PI speaker to build [message #92761 is a reply to message #92756] Sun, 13 December 2020 21:47 Go to previous messageGo to next message
The four Pi speaker is an excellent model for your needs. It's very popular and has a lot of options, so you can choose whatever fits your needs. Lots of people have built 'em on here too, so you'll have an abundance of support.
I would also encourage using flanking subs, but those can be built later. So you can upgrade parts within the speaker as time and funds permit, and you can also add-on subs later for a whole 'nother dimension in sound.
Re: which PI speaker to build [message #92765 is a reply to message #92761] Mon, 14 December 2020 11:10 Go to previous messageGo to next message
Thanks for the fast help Wayne, that sounds good.
I would like to have them as stand-alone speakers for now and maybe add the subs later.
My plan would be to build them as floor standing speakers to not need any speaker stands. To do so I would probably just extend the cabinets. Question is whether the additional volume can be used to achieve a few Hz more low end or whether I shall rather keep the available speaker volume the same and really just extend the cabinet. 50 Hz -3dB in room are good if it can be achieved but 30..40Hz would be perfect for me for just music listening usage.
In regards to the upgrades: I struggle with the JBL driver upgrade for now due to it's price. For the price wise smaller upgrades I consider the compression driver upgrade. Are any of the other upgrades recommended right from the start?
Re: which PI speaker to build [message #92766 is a reply to message #92765] Mon, 14 December 2020 12:19 Go to previous messageGo to next message
Please read the following links from the Pi Speakers FAQ:
Re: which PI speaker to build [message #92768 is a reply to message #92766] Mon, 14 December 2020 16:46 Go to previous message
Thanks, that clarifies what I will do: I won't mess with the design at all, will extend the cabinet while keeping the actually used volume identical.
Previous Topic: 2Pi Speakers
Next Topic: Loft Dance Soundsystem Suggestions
Current Time: Fri Nov 06 06:41:30 CST 2026
