Home » Audio » General » Optimizing Audio on YouTube
Optimizing Audio on YouTube [message #92760] Sun, 13 December 2020 20:52 Go to next message
PinkHair is currently offline  PinkHair
Are there any steps to take to optimize audio for low-bitrate output? Specifically, I'm wondering how to achieve the best results with YouTube's 128kbps audio.
Re: Optimizing Audio on YouTube [message #92830 is a reply to message #92760] Sun, 20 December 2020 21:19 Go to previous messageGo to next message
Last I checked, you can't create more bits more often from whatever source you have. Best suggestion is better playback equipment. If that means you hear too much of the nastiness, many less capable playback equipment. In other words, play around more with what you have and see how far you get, or get better sources to see if that helps.
FWIW, I can certainly tell the difference between a CD and a LAME ripped version of the same song from that CD, and CD's aren't known for their sonic reputation.
Chris
Re: Optimizing Audio on YouTube [message #92832 is a reply to message #92830] Sun, 20 December 2020 21:34 Go to previous messageGo to next message
This isn't the fanciest solution, but just wearing some decent headphones can make a big difference when it comes to enhancing the audio quality of YouTube videos.
Re: Optimizing Audio on YouTube [message #92850 is a reply to message #92760] Fri, 25 December 2020 15:58 Go to previous messageGo to next message
I wasn't super clear in my original post. I'm looking to optimize audio for other people who are listening. I have YouTube channel, and I want my subscribers to have the best audio experience when watching my videos. I'm wondering if there's something I can do from the creator's end.
Re: Optimizing Audio on YouTube [message #92867 is a reply to message #92760] Sun, 27 December 2020 19:05 Go to previous messageGo to next message
As far as playback, I got "premium", so I get a 256k rate.
As far as recording, I would record as high of rate possible and
see if YouTube receives it as is, or the need to lessen the rate.
Of course, as high fidelity as possible.
cheers and hope this helps.
pos
Re: Optimizing Audio on YouTube [message #92914 is a reply to message #92867] Tue, 05 January 2021 16:59 Go to previous messageGo to next message
Another trick I learned is to search for the video like usual, but add HQ or high quality after the search term. Sometimes there will be a better quality upload if you can just find it.
positron wrote on Sun, 27 December 2020 19:05
Was it worth the expense? I'm not that familiar with YouTube's paid for stuff.
Re: Optimizing Audio on YouTube [message #92915 is a reply to message #92914] Tue, 05 January 2021 17:38 Go to previous message
Thanks for the info Madisond. Much appreciated.
I, personally, found Premium YouTube to be quite worthwhile. But then I used to
be a Designer/Manufacture, retired now.
Of course one must consider system/room quality.
cheers and thanks again.
pos
Previous Topic: The Trees And The Flute
Next Topic: Strange Animal Noises
Current Time: Sat Nov 21 23:11:58 CST 2026
