What type of music/bands/songs would you say is best for the initial set-up of a brand new system? Of everything out there we can listen to, which has the broadest range that we can tweak the settings to in order to get the best sound out of everything else we play?
Wayne Parham Messages: 19105 Registered: January 2001
Most people prefer to audition systems with material they are familiar with. I think it helps if the material has lots of range, both in terms of dynamics (soft to loud) and frequency (low to high). I also like to have material that has some percussive and/or staccato notes, because this kind of material exposes decay and impulse response anomalies.
Frank Zappa might be good for this. His stuff was all over the audio map.
I think the best "intro" audio might be the best representation of what you like. For instance, I listen to mostly classic rock, so Pink Floyd is what I would use. Slap in Dark Side Of The Moon and tweak on the knobs until it is just right.
