Home » Sponsored » Pi Speakers » Definimax 4012HO - End of Life
| Re: Definimax 4012HO - End of Life [message #91818 is a reply to message #91816] |
Mon, 04 May 2020 12:47   |
Messages: 19101 Registered: January 2001
I agree with you, 100%. Those B&C midwoofers are really nice. It's a wonderful top-notch in the upgrade path for the three π model loudspeaker. I think this 2020 version is the best that the three π loudspeaker has ever been.
I also agree with you on the Delta Pro. It's a good driver, and worth the small additional cost over the entry-level midwoofer option. It is also higher in sensitivity, so the R1/R2 values need to be populated specifically for that driver compliment. This makes the overall sensitivity as high as the four π model, when the Delta Pro driver is used. The bass response doesn't run as deep with that option, but when used with flanking subs, the extension isn't needed.
Standing wave modes on larger full-range speakers are always a potential problem, as you've seen in your modded box. My cabinet design efforts were more extensive and difficult as a result. This was the case for the four π, three π and two π tower models.
Smaller cabinets and subwoofers are much easier to design, because standing waves don't line-up in the lower midrange. In smaller boxes, the standing waves shift up into the overtone region where insulation on the walls does a good job damping them. In subs, midrange isn't presented so they can't develop standing waves. But large full-range boxes need a little more tender loving care in the design phase, because they are prone to developing standing waves in the lower midrange where they are difficult to deal with.
What I've done is to model the modal behavior within the loudspeaker cabinets, much like modeling room modes. Several years ago, I purchased license to Martin King's spreadsheets to help analyze internal standing waves. I used them to design my larger model full-range loudspeakers, adjusting the size and shape of the box and setting the position of the midwoofer and the port for minimum standing wave anomalies.
As an aside, I didn't have to adjust size/shape of the three π or four π cabinets, but I did manipulate where I put the driver and port in the box. Sometimes just moving the midwoofer or port an inch or two made a big difference. The tower two π speaker - being tall and thin - benefited from adjustment of both cabinet dimensions and driver and port positions.
I am not sure if Martin King is still selling his spreadsheets or not. But you might be able to use the same kinds of tools used to model room modes. The potential problems I see with that approach is the size of the loudspeaker cabinet is small compared to the size of a room, so the tool may not allow the right size chamber to be created. Also, room modes are below 200Hz or so, and we need to analyze the chamber modes over an octave above that.
So if I were going to try to find modal analysis tools to help me look at the cabinet, I would try to find ones that could model chambers down to 2ft3 with each dimension only being a foot to a few feet long. I would also look for tools that could analyze frequencies up to 500Hz. I wouldn't care whether it could go above that, because damping material placed on the walls of the cabinet is able to absorb the sound pretty well at higher frequencies.
What you want to look for is where the "hot spots" are, especially in the 100-500Hz range. We can't have any in this range in the same location as the midwoofer or the port. If a mode exhibits a pressure maxima where the driver or the port are, it will result in a peak at that frequency.
And finally, you'll find that fiberglass insulation that spans the cross-section does wonders for damping midrange frequencies too low to be damped by insulation attached to the inside walls of the cabinet. That's the trick for damping lower frequencies - Space the insulation away from the walls where it can damp pressure nodes better at those frequencies.
By: rkeman on Sat, 15 June 2019 20:24
By: Mudshark on Tue, 03 September 2019 12:07
By: Mudshark on Wed, 04 September 2019 15:43
By: Mudshark on Thu, 05 September 2019 08:24
By: Mudshark on Sat, 07 September 2019 17:39
By: Mabob on Thu, 05 September 2019 06:15
By: Mudshark on Sat, 07 September 2019 17:59
By: Mudshark on Mon, 09 September 2019 10:30
By: Mabob on Mon, 07 October 2019 08:01
By: Mabob on Fri, 11 October 2019 11:42
By: Scott L2 on Mon, 15 January 2024 06:48
By: Scott L2 on Mon, 15 January 2024 14:03
By: rvsixer on Sat, 25 July 2020 11:14
By: rvsixer on Sun, 26 July 2020 13:30
By: rvsixer on Thu, 28 January 2021 14:26
Current Time: Wed Oct 14 11:34:00 CDT 2026
