Home » Audio » Thermionic Emissions » Fisher 500C-how hot is too hot?
Re: Fisher 500C-how hot is too hot? [message #9177 is a reply to message #9176] Sun, 04 September 2005 21:52 Go to previous messageGo to previous message
Thanks for the help. I've never been any good at math formulas.
I changed the resistor on the bias bridge rectifier-to-ground from 15 ohms to 2 ohms and got the voltage to -24 VDC. This also, unfortunately, raised the fillament voltage on four 12AX7's higher than what is good for them, so I added a 16 ohm resistor in series whith them and have them right where they should be.
I'm a bit worried about reducing the bias resistor anymore. Not sure if the transformer tap and rectifiers are up to a lower resistance than this or not (not sure if it's up to the valule I have on it now.) Is -24 V close enough, or should I try an even lower resistor?
Dave
Previous Topic: One output transformer hotter than the other
Next Topic: DRD 45's in gear.
Current Time: Thu Nov 05 06:37:46 CST 2026
