Home » Audio » Thermionic Emissions » Fisher 500C-how hot is too hot?
Re: Fisher 500C-how hot is too hot? [message #9176 is a reply to message #9175] Sun, 04 September 2005 17:59 Go to previous messageGo to previous message
With OP - Ua=440V, Ug2=320V, Ug1=-20V, you can expect more then 100mA Ia+g2 current through each EL34. Much more then Pa max for EL34. For "resonable" bias of about Ia~50mA (and Ig2~5mA) you should change the "bias voltage" Ug1 to about -26V. If you don`t have adjustable "bias" pot, you can change the values of voltage divider resistors in "bias" supply to "enlarge" Ug1.
Previous Topic: One output transformer hotter than the other
Next Topic: DRD 45's in gear.
Current Time: Wed Nov 04 16:37:58 CST 2026
