My questions are:
My room is 16x28.5', the front wall is the 16' wall. The right corner on this wall has a 5' opening after just 4' 5" from the corner, is this workable for the cornerhorn? The other wall is solid .
I just purchased a pair of Eminence Kappalite 3015 LF-4, a 4 ohm driver, is that something that could be corrected for in the crossover? I have attached the data sheet, it appears most of the parameters are similar to the driver you designed to.
Wayne Parham Messages: 18726 Registered: January 2001
Your room orientation is perfect for constant directivity cornerhorns. However, you will need to stick with the driver shown in the plans. Horns are pretty picky about the driver, and reflex-loaded horns even more so. The eight Pi speaker requires the Alpha 10 midwoofer.
You could probably put the Kappalite 3015 in the bass bin of the seven Pi cornerhorn though. That design isn't nearly as picky about the driver in the bass bin. Do keep in mind that the design hasn't been tested with that driver though.
Please let me know which model you want to build and I'll send plans.
