Home » Sponsored » Pi Speakers » 4PI Plans Request
Re: 4PI Plans Request [message #91260 is a reply to message #91257] Sat, 14 December 2019 09:53 Go to previous messageGo to previous message
You've got mail!
Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
I recommend using only MDF or Baltic Birch. You will probably want to purchase wood at a quality lumber yard, because the large chain retail hardware stores do not usually stock MDF or Baltic Birch. They only sell cheap plywood products and chipboard. Both of those are suitable for many construction projects, but not for loudspeaker cabinets.
Please peruse the Pi Speakers FAQ. I think you will find the answers to all of your questions there, as well as answers to many things you haven't thought to ask yet. The FAQ has information about upgrade options, the differences between models and upgrade choices, build and setup advice and other useful things. And as you start your build, please feel free to document it here and ask questions or make comments along the way.
Previous Topic: Flanking subs
Next Topic: For Sale: 4 Pi speakers (upgraded drivers) + pair of 3pi flanking subs
Current Time: Thu Sep 24 14:16:00 CDT 2026
