Home » Sponsored » Pi Speakers » MiniDSP (Active Line Level Crossover)
Re: MiniDSP [message #91227 is a reply to message #91225] Wed, 27 November 2019 15:33 Go to previous message
Digital filters are awesome because of their flexibility.
In the case of loudspeakers - and particularly controlled directivity loudspeakers - you have to be careful with your choice of filters because they affect summing through the crossover region. So steep slope filters aren't necessarily your best bet. Nor are first-order filters necessarily your best bet.
In my experience, the best filter is found using a process like I describe in the link below:
And for room modes, no electrical filter is sufficient because the most sophisticated filter can only have a two-dimensional effect, whereas room modes are a three-dimensional phenomenon. The solution for room modes is flanking subs and multisubs.
Previous Topic: Just finished 4pi build need some tips
Next Topic: 4PI cabinet drawing
Current Time: Fri Oct 30 16:10:57 CDT 2026
