Home » Sponsored » Pi Speakers » Three Pi and Three Pi Sub Plans (Plan Request)
| Three Pi and Three Pi Sub Plans [message #91007] |
Wed, 02 October 2019 14:22  |
timothyeyster
Messages: 11 Registered: October 2019
Chancellor |
Hi, Wayne.
Firstly, thanks for sharing all of this fantastic information and for providing your products to the DIY community!
Secondly, I purchased a pair of your H290C waveguides yesterday to go with a pair of DE250s I have (thanks for shipping those so quickly, by the way), and would love a copy of your plans for the Three Pi and the Three Pi Subwoofer to look over. Could you also please point me toward the appropriate crossover schematics/layouts?
Lastly, when I decide which woofer I'd like to use in my builds, is that something I could purchase from you a-la-carte, or do you only sell those packaged within the kits?
Thanks again,
Tim
| Re: Three Pi and Three Pi Sub Plans [message #91068 is a reply to message #91013] |
Sat, 12 October 2019 16:49   |
timothyeyster
Chancellor |
Wayne,
Thanks for sending those over!
The 3Pi design is really elegant, and, I'm convinced, would perform incredibly well. Unfortunately, after much consideration, I just don't think it will shoehorn into my space due to the cabinet size.
I started modeling alternative boxes in WinISD, and think I found a good compromise: Using the B&C 12PLB100 woofer you've identified, I tried B&C's recommended box size of 1.41 cuft tuned to 52HZ, and came up with a ruler-flat response to 60HZ that then slopes quickly to -3db at 50HZ. This seems like acceptable low frequency cutoff to me, especially if used with flanking woofers.
However, after reading your thinking behind the larger box with the EBS alignment, and how it's meant to play lower and integrate better with flanking woofers, I'm wondering if I'd lose more than just a little low end extension using this smaller box. I'm also wondering if I were to change the box alignment, if a substantial redesign of the crossover will also be required.
Having already gotten so much great information from you and this site, I feel bad asking for more. But, if you would be willing to share your thoughts on this, or point me toward further reading, I'd sure appreciate it.
Thanks again,
Tim
| Re: Three Pi and Three Pi Sub Plans [message #91085 is a reply to message #91083] |
Mon, 14 October 2019 14:33   |
timothyeyster
Chancellor |
Thanks for the great response; that's exactly what I was trying to understand. Again, the design seems very elegant, and I wish I could accommodate the cabinets in my room.
I have been thinking about building a baffle wall, however, as I already have an AT projector screen, but am unhappy with the in-wall speakers installed behind it currently. If I understand correctly, these proposed shrunken Three Pis set into that baffle would not suffer from baffle step loss, so should perform quite evenly down to their roll off frequency excepting interference from room modes. Is that correct?
Then, at that point, would you still recommend the flanking subs, or would it make more sense to just run several distributed subs crossed at a lower frequency?
Again, thanks for all of the great info!
| Re: Three Pi and Three Pi Sub Plans [message #91086 is a reply to message #91085] |
Mon, 14 October 2019 17:13   |
If you can mount the speakers in the wall, that's perfect because it removes self-interference from the wall as well as removing any baffle step. It really is the best option. You can setup the subs as distributed multisubs rather than flanking subs.
However, you will lose the left/right self-correcting imaging if you don't toe them in so that their forward axes cross in front of the listeners. Is it possible to do that to the left and right speakers? Can you provide a wedge-shaped baffle that connects to the wall and still offers toe-in?
If you cannot, it isn't terrible for movies, especially if you have a center dialog channel. But it is really nice because the left and right speakers are balanced over a wider range of positions. When the axes cross, people sitting nearer the left speaker will still hear the right channel very well, and vice versa.
As I said, it isn't terrible to forego the axes-crossing for home theater if you have a center channel. But it is better to have both a center channel and left/right axes crossing. And if you don't have a center channel, like when you are listening to stereo, or if you are attempting to create a phantom center, you'll really benefit from the toe-in that crosses the axes in front of the listeners.
| Re: Three Pi and Three Pi Sub Plans [message #91221 is a reply to message #91086] |
Sun, 24 November 2019 16:36   |
timothyeyster
Chancellor |
Wayne,
After much consideration, I ended up building a pair of Three Pis per your plans. They are a bit dominating in my current room, but will eventually go behind an AT projector screen (hopefully with enough space to cross their forward axes properly). In terms of the sound, I'm very happy with the dynamics, detail, and imaging- really nice sounding speakers. I noticed right away that the high-end balance is very depressed compared to most other speakers I've had. Running an Audyssey auto setup brought them much more in line with my preference, but shelved the high end nearly 10db. Does that seem normal with these, or might I have made a mistake building the crossovers? I'm using the DE250, and the B&C 12PLB100 woofer.
Also, though the bass is quite good, I'm eager to add the Three Pi flanking subs to complete the picture. I ordered a pair of kits from your site last week, and look forward to building the boxes shortly. Could you please clarify for me how best to accomplish the port on these? Is there something included in the kit, or do I use PVC pipe?
Thanks again for all of the great information!
Tim
| Re: Three Pi and Three Pi Sub Plans [message #91267 is a reply to message #91222] |
Sun, 15 December 2019 21:28   |
timothyeyster
Chancellor |
Wayne,
After experimenting a bit with placement of the Three Pis, and particularly with tilt-back, I'm much happier with the treble balance. Audyssey still assigned about 6db of high-shelving, but I think that may be baked into their reference curve. In any case, they're sounding great now!
I received my Three Pi sub kits last weekend, and plan to cut and assemble boxes for them this week sometime. It's looking like I'll have no option but to place them inboard of the mains which are shoved in the corners, but I imagine I'll still gain some advantage configuring them as flanking woofers (namely, crossed at 100hz, 2nd order and fed discrete copies of their respective left and right signals) versus just running them as mono LFEs, right?
Also, I'm thinking of rounding out my surround system with a pair of One Pis; could I trouble you to share those plans with me? Does the kit you offer include the crossover parts?
Thanks again!
Tim
Current Time: Sat Oct 24 11:12:22 CDT 2026
