Home » Audio » Craftsmen » Where do you look for ideas?
Re: Where do you look for ideas? [message #90876 is a reply to message #89989] Tue, 17 September 2019 16:00 Go to previous messageGo to previous message
I search the web for ideas.
Punch in exactly what your looking for and add the word "diy" or "kit" or both.
I agree with Wayne.
Sometimes you must diy to get things exactly how you want.
I built a kit replica of a 1965 Shelby cobra years ago. This kit was like a blank easel....just a great starting point.
It was designed with a few things that I would not compromise on- exact 90" wheelbase (not stretched)- round tube ladder frame like the originals (although 4"D instead of 3"D and 1.20 wall thickness instead of .90) also a very accurate body laser measured from an original.
The accuracy of the body was not exactly important to me, since even the originals varied quite a bit being hand made panels.
There was no way I was able to afford an original, or even a continuation series Shelby.
Even the high end kits or replicas are way out of my price range. So diy kit it was!
A 427 side oiler was unobtanium for me, not to mention pretty much UN drivable,
so I went the cheap route with a mustang (1990) donor car, using the motor and trans, front control arms and brakes. Obviously purists cried foul-
It must have a big block side oiler!, it must be carburated!
What a blast that car was, cat on carpet handling and could scare the pants off of almost any passenger if they asked for it LOL.
It only weighed 2,300lbs after all..
Previous Topic: 1942 Ducati Radiogram
Next Topic: Creating a Projector at Home
Current Time: Thu Nov 05 15:52:19 CST 2026
