Home » Audio » General » Removing Background Noise
Removing Background Noise [message #90672] Thu, 11 July 2019 08:41 Go to next message
Groot is currently offline  Groot
Is it possible to remove background noise through digital editing? I recorded my friend's song, but there were vehicles passing and dogs barking in the background, which I would like to remove. Is this a hard thing to do or would there be an application I can use for this purpose?
Re: Removing Background Noise [message #90692 is a reply to message #90672] Fri, 19 July 2019 20:39 Go to previous messageGo to next message
Hi, Yes it is possible. A program like Audacity will do it. Low level residual noise can be reduced in bulk in a recording and specific sounds one at a time. Please note though that a barking dog or passing car will not be possible as the maximum length of a single fix/repair is set by the program and it won't be able to smooth over such big things.
Re: Removing Background Noise [message #90956 is a reply to message #90672] Sat, 28 September 2019 09:40 Go to previous message
Groot wrote on Thu, 11 July 2019 08:41
Part of the signature sound for some bands, Pink Floyd for example, IS the background noise. "Nobody Home" is a great example.
Since you can't eliminate it, see if it's possible to move those sounds to different parts of the song so as to make it sound like it was done to enhance the song.
Previous Topic: Your most disappointing buy?
Next Topic: Tapping The Microphone
Current Time: Tue Oct 20 18:38:32 CDT 2026
