Home » Audio » Measurement » Help with testing frequency response
Re: Help with testing frequency response [message #90688 is a reply to message #90687] Tue, 16 July 2019 17:28 Go to previous messageGo to previous message
You'll need a sound card that supports that microphone and some measurement software. I doubt your laptop can connect that microphone, so you'll probably want to buy a USB device that acts like a sound card having analog-to-digital and digital-to-analog converters and amplifiers built-in. Several have microphone inputs like you need that provide the right connector and 48v "phantom power" for that microphone. Your microphone manufacturer makes such a device, for example, the UMC404HD. They actually make a lot more than just that device, but it's a simple stereo unit that I've worked with.
As for software, there is a lot of shareware and freeware out there that you can get started with. I personally run WTPro and LMS, and neither is free. So I can't personally recommend any of the freeware/shareware products from personal experience. But i can say that there are a lot of passionate individuals and small teams that have written software for acoustic measurement, so there's a lot out there to choose from.
Start by buying a USB sound card. Then do some searches for acoustic measurement software that you can download and try. Once you get started, report back and we'll help keep you moving forward.
Previous Topic: Measuring noise levels
Next Topic: Cassette Tape Alignment
Current Time: Sun Sep 27 12:11:32 CDT 2026
